Isuzu ABS issue
what ISuzu in what body. KB? backie>? in what country>?
first off the brakes must be good for ABS to work
so we inspect brakes or
or we use a real ABS scanner, the PCM scan tools do not scan ABS, (in most cases) so you need to use the correct tool.
The ABS tool will in fact show a code. for sure.
sounds like your Isuzu shop is incompetent to me.
are you tell us that you took the car to Isuzu and the ABS light was off?
well if that is true then , it can be impossible to fix.
after all , you cant fix that which is NOW working.
if that is true,. only scanning the ABS failed works.
see?
or if lucky the brakes just need service.
(pads bad)
stuck caliper pistons. (hanging up, hot)
caliper guides stuck, (same reason)
air in the system, seems not.
ask the mech to drive car for day with a real ABS scanner in the car, and when it fails , scan the ABS.
or buy one your self and do that.
or if rich replace parts 1 by 1 in the blind hope of finding which part is intermediate. $$$$$$$$
scan the ABS not the PCM the PCM only knows ABS is failing.
scan the ABS to see all ABS codes.
and do so , only with ABS lamp glowing.
