Electrical Supplies Logo
A
Anonymous Posted on Apr 25, 2014
Why does my generator start but no output ?
The generator starts but does not give any output. Oil and fuel ok.
5 Related Answers
Anonymous
  • Posted on Mar 16, 2009
SOURCE: Generator will not start
You say there is compression .What was the p.s.i. on the gauge. If below 100 p.s.i.. May have bad ring, valve out of adjustment or bad head gasket. Is there spark and what does spark plug look good, is gap ok . Is the fuel tuned on and kill switch on. Will need more info to help out more.
Phil Rivera
  • 83 Answers
  • Posted on Mar 30, 2009
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 09, 2010
SOURCE: the engine does not give out voltage
http://www.flightsystems.com/pdf/onanrvtshootgd608.pdf
troubleshooting manual above, all generators are same principle, so this manual is representative of ANY Generator.
Anonymous
  • Posted on Jul 12, 2010
SOURCE: McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Sep 04, 2011
SOURCE: Brand new B&S 5000 watts
There really is not much you can do without voiding your warranty. This may be something simple like a connector that vibrated loose inside the control panel. (Alternator to contol panel inter-connect) There could also be a wire lying loose that was not connected. Open the control panel... and look for anything obviously out of place. DO NOT do anything else. After that your stuck with the warranty process of Briggs and Stratton.
http://www.briggsandstratton.com/~/media/PDF/BriggsStratton/Engine_Warranty.ashx
or 1-800-233-3723
When your at a B & S service / repair point... (store front)
Things to note .
1. Tell servicer unit is for PRIVATE USE (There is no warranty for commercial use)
2. Have proof of purchase in hand otherwise they will use the MFG date as the start point of the warranty. Many generators sit in a warehouse or on the shelf long past an implied warranty (date of mfg) Bottom line you need to have your sales slip.
There are several things I could have you do but... as the consumer the only thing you can do is perform an inspection. By opening the control panel you need to tell the servicer the only thing you did was a VISUAL Inspection...... Anything else will void your warranty.
So.. look for any obviously loose parts or or connectors. After that sadly your stuck with dealing with warranty service.
Thanks for choosing FixYa,
Kelly
1helpful
I have a Clark 2200 generator which does not generate electricity, it starts ok with the choke in the start position. Once running the choke is moved to the run position, no change in revs,
If the generator is turning and has no output,it may need to be magnetized.Somewhere on the generator part of the unit there should be a + and - most likely on the end of the generator,use a 9 volt battery and send a small charge through the + and - while its running.Once it starts charging again it should hold it's magnetization for at least 1 year if not used.
1helpful
I have kipor 6700 diesel generator when I'm trying to turn it on the starting motor works but engine doesn't start even though I tried for 8 times the battery is ok and oil level is ok 2- there is oil in...
no -it is not normal. check that it is oil as I suspect that it is diesel fuel and the reason that you can't start it is because the fuel is leaking out and letting air into the system. If so you will have to bleed the system before the engine will start.
Have a mcculloch fg5700ak portable generator. 7 yes old. Used 1 time for 20 hours. Sitting up since. Gas was drained so carburetor fine. Turn everything on and pull cord and it just won't kick on over and...
Make sure fuel tap is turned on. Tap the bottom of the carburettor with a wrench to make sure the float isn't stuck. Is the ignition on/off switch in the on position? make sure the oil level is ok as these usually have a low oil cutout which stops the motor when oil gets low. All that being ok give it full choke and it should start. Remove the sparkplug and check there is spark across the electrodes. (earth the thread part of plug on motor) If no spark replace the sparkplug.
Generator starts but only runs for 1 or two minutes then dies
Check oil pressure and sender, check fuel pressure and fuel solenoid. Check stator resistance and output voltage. Manuals can be found by contacting:
http://www.advanced-power-technologies.com/coleman-power-station-generator.php
UNIT SHUTS DOWN FREQUENTLY
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
3answers
Diesel generator does not working
After using a diesel generator for a long time, some malfunctions may occur that will cause the generator fail to start.
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
1. Air in the fuel system
2. Fuel line obstruction
3. Fuel filter clogging
4. The handle position of fuel injection pump is not correct
5. Battery power shortage
6. Run out of fuel
Learn more reasons from this article.
Why Diesel Generator Fail to Start
Top Pramac Electrical Supplies Experts
littlewheel
Ngoro
john h
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
