The top button on my Iphone doesnt work. I cant get it to sleep mode and i cant get it to turn off. Is there any trouble shooting around this?
SOURCE: How to work the iphone sleep and wake button?
Hey D, It's quite simple. Check this out: With the iphone open press the sleep button to lock your screen. From this moment on the screen will no longer be active but all other functions will continue to work- which means that you will still receive calls and can continue to listen to music. To turn the screen on just click on the sleep button once again. You?ll need to confirm the action by sliding your finger across the virtual slider on the screen. Hope this helps! Volcane
SOURCE: sleep/wake button jammed
Well that is a common problem you may come to the Apple store nearest you and they will swap you iPhone.
Please note:Sync your iPhone with your Mac or PC to have a backup file when you get your new iPhone so you can have your latest contacts on your computer.
Thank you,
Apple Care Technical Support
1-800-275-2273
SOURCE: my iphone wont go past the apple logo
hi juli this is glady even i faced the same prob in my i phone to so download a new firmware from apple site nd then switch off ur cell while conectd to ur pc then switch on through ur apple pc suite upgrde ur phone through the i tunes o give the path nd see or better to go to youtube for more crystal clear info bye
SOURCE: sleep button wont work and its disabled
Could you clarify what is the sleep button?:
- The home button on the front
- The power button on the top
- or the vibration disble button on the left
Probably the flex cable that connects the button to the motherboard is not working. These parts are cheap and easy to install. You can find the replacement connectors for all these buttons here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Testimonial: "nice one mate, thanks."
SOURCE: my iphone home button not working
May be the flex cable that connects the home button to the motherboard is damaged. This part is cheap and easy to install.
You can find a replacement here:
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
