Question about Nikon D60 Digital Camera
Nikon d60 intermittent flash
At times will not flash in the dark,flash pops up but not flash and even the shutter will not work
SOURCE:
SOURCE: Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Posted on Jun 28, 2009
tonyy168
  • 45 Answers
SOURCE: have a nikon d60 and the flash will not go off
if it pops up then the sensor is working and the mechanical parts are working,
Next is manual force flash test, if is manually flashes, the bulb is good else replace the bulb.
Posted on Sep 15, 2009
richard191
  • 691 Answers
SOURCE: WHY DOES MY NIKON D60 BUILT IN FLASH FAIL TO WORK
Hello
Thank you for using
FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 30, 2009
  • 51 Answers
SOURCE: My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Posted on Jan 03, 2010
SOURCE: Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Posted on Jan 06, 2010
I have a nikon d60 and cannot get the pop up flash to work, any help would be appreciated.
there is a button just to the left of the flash on the camera that should pop up the flash or if you are in auto mode it shoud pop up by itself.. if these do not work then your flash is stuck and you could just pull up in it and it should open but I dont recommend that just in case you break it.. but I have done that several times
Nov 13, 2012 | Nikon D60 Digital Camera
My camera is set on auto but the shutter speed is very slow. On the screen at the bottom the question mark is flashing.
this condition sometimes happen in dark condition while you take a picture,
built-in flash will help very much in this condition
Oct 22, 2010 | Nikon D60 Digital Camera
Hello i have nikon d60 and the flash do not pup out
In what mode(s)? In the point&shoot modes the camera decides whether to pop up the flash. In PSAM modes you decide.
Dec 25, 2009 | Nikon D60 Digital Camera
Have a nikon d60 and the flash will not go off even when in a dark situation. Pops up but no flash?
Sep 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Aug 14, 2009 | Nikon D60 Digital Camera with 18-55mm +...
D60 won't turn on
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick. Tonya
Aug 07, 2009 | Nikon D60 Digital Camera
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
I use first time nikon d60.
it would depend on the lighting. you can lower down your shutter speed, or change the white-balance or aperture on the camera. make sure that your camera is set on manual. hit me back on the results.
Jan 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Re: nikon 5700 faulty flash
I've had this problem and Nikon repaired it twice for me at about Aus$200 each time.
Recently it happened again.
Quite by accident, I found that I could lift the black on-off main switch and that it comes off the camera body quite easily together with the chrome shutter button.
Inside was a little plastic tab with contact points.
Merely blowing off the dust inside and then replacing the shutter button and on-off black ring appear to have solved the problem for me.
However, my viewfinder and lcd were working normally and not black as  lsvettek said.
I did have a problem with the viewfinder and lcd on yet another occasion and this was a recognised fault which Nikon repaired free of charge.
Nov 09, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon D60 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
