SOURCE: Won't Focus!
This is probably a CCD failure. I had the same problem and it was fixed for free. Go to the Canon website and you will find info on returning for free repair. Check out the following website: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
SOURCE: My camera will only take pictures of a purple screen
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
SOURCE: Canon digital IXUS 970IS, pink/purple screen images
Sounds like a CCD image sensor problem, not a do-it-yourself repair, but this would also definitely fall under warranty repair. The IXUS 970IS is a relatively new camera, and thus your camera should likely still be under warranty. Recommend that you contact Canon directly to arrange warranty repair. If in US or Canada, call 1-800-OK-CANON. All others, www.canon.com, select "Support" and then your Region for further info in your local area.
SOURCE: purple streaks on LCD monitor
This sounds like it might be a defective CCD imager. But you didn't mention the make or model of your camera. This is important as if it's an older Canon or Sony, it might be fixed for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
SOURCE: My canon s60 no longer displays an image on the
How about brand new images just taken, are they also black? If so, this sounds like it might be a defective CCD imager. Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
