SOURCE: vpl-es4 sony projector-frequency out of range
change the screen resolution to 600x800,and switch to other monitor by hitting fn+F6 key (Laptop).if the screen get black use alt+Ctrl+F3 to switch it on .
thanks
Hussam
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
SOURCE: how to rest lamp timer vpl-es4 - reset < >
http://www.kavena.se/fileadmin/uploads/downloads/Sony/Projektorer/VPL-EX4/Protocol%20EX4.pdf
That's the link, to reset this unit, it seems you must hook, up with an RS232C cable, and "Talk" th the Projector, You simply hook up, using any terminal Program. such as, Hyperterminal. I think you need to get a manual.
http://www.nodevice.com/user_manual/sony/projectors1/vpl-es4.html
I looked but could only find, pay for links, for the service manual. You really need this if you own anything it is worth any money, as in it is the information, the the engineers that service them, use to troubleshoot and fix, special codes, and settings the lot. So it is a must have.
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Testimonial: "Thanks! And please tell me where is the lamp cover located."
