Tefal UltraGlide Easycord FV4256 Iron Logo
A
Anonymous Posted on Apr 25, 2014
Can i get instructions for t-fal fv4476 - Tefal UltraGlide Easycord FV4256 Iron
How to take apart the T-fal 2349 iron
Get a new one... They aren't built to be taken apart.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 • Irons
How to put water in T-Fal Latitude 30 travel iron
Hello -
You can find and download the user manual for the Tefal Latitude 30 travel iron from this Tefal web page:
https://www.tefal.com/instructions-for-use/Products/Linen-Care/Dry-iron-and-Travel-iron/csc/DryIronAndTravelIron
Scroll down on that web page to near the bottom. There you should see a heading for Travel Iron and an icon and link for Latitude. Click or tap on the Latitude link.
That will bring you to the Tefal web page for Tefal LATITUDE User Manuals:
https://www.tefal.com/instructions-for-use/Products/Linen-Care/Dry-iron-and-Travel-iron/Travel-iron/LATITUDE/csp/2800000013
On that web page in the section headed Instructions and Manual (with an icon for Warranty Information) you should see a search box with a drop down menu and the direction "Choose a language for displaying the instructions and user manuals:" Click or tap on the downward pointing arrow on the right end of the search box and choose the language you want for the manual.
A Download Manual icon will appear. Click or tap on it.
Then, you will see the PDF document for the user manual. You will need Adobe Acrobat Reader (free) software.
The first illustration of the iron you should see in the manual indicated where the Water Tank Filler cap is located near the tip of the iron handle. The water tank is within the handle.
Best wishes.
2helpful
My ultra T-fal iron is leaking right out of the iron, before I turn it on. Should I get a new iron, or can this be fixed?
I believe there`s faulty construction'and the cost to repair is about as costly as a new purchase.The valve that inhibits the water flow apparently is remaining open.
Mar 04, 2013 • Irons
1helpful
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
When empty, fill with white vinegar, let it heat up then hold the steam button down to let the vinegar run through the iron. Do this over the sink!! Then fill with water and repeat to rinse the vinegar out.
The vinegar will dissolve the mineral deposits in the iron.
Re: cleaning the iron
Here is a tip that will help you with cleaning the bottom of your iron...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
1helpful
Need way to open the iron 3302
Usually start at the cord end to locate internal screws to get top off then down to the next layer
Top Tefal Irons Experts
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Tefal Iron Expert? Answer questions, earn points and help others
