Hello. i wonder if you can help me. i have GE above the cooktop oven. the turntable is not turning. whats going on? how can i fix this without calling the GE service men? is the fuse out? everything else functions. its only the turn table thats not turning. please give me any tips if you can. thanks in advance. William from CA
SOURCE: GE Above the Cooktop Oven Microwave JVM1533 Turn table does not move
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
In this case, I would suspect the primary interlock door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Turn Table wont turn
if you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
