Sewing Machines Logo
S
Sheila schmidt Posted on Apr 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find an online user manual for Bernina Bernette 46
On the Bernina Bernette 46 how do I sew a straight stitch. I don't see a dial for it-only buttonholes, decorative zig zags, ect Also how do I sew a basic zigzag?
outlawnnm
Level 1:
  • Contributor 7 Answers
  • Posted on Feb 09, 2015
outlawnnm
Contributor
Level 1:
Answers
7
Questions
Helped
896
Points
17
You can find most Bernina manuals here. Berninamanuals.com Have a great day.
Archie Cruz
Level 3:
  • Master 641 Answers
  • Posted on Apr 25, 2014
Archie Cruz
Master
Level 3:
Answers
641
Questions
0
Helped
163732
Points
1736
Hi Sheila,
I have this manual for you that might help your question. Hope it helps.
Bernina Bernette 46 Manuals
Why my bernette 05 academy don t stitch.
There could be a few reasons why your bernette 05 academy is not stitching correctly. Firstly, ensure that you are using the original bernette stitch plate, as well as a new BERNINA quality needle. If this does not solve the issue, contact a specialist bernette dealer to have the damages repaired. Additionally, make sure to check the tension of the upper thread and the needle position when selecting a stitch width. If these do not resolve the issue, contact a specialist bernette dealer for further assistance.
I can’t get the tension on my Bernina 65 correctly set. There are three dials on the top that I find no reference for in the directions. PLease help
The manual for the Bernina Bernette 65 are available from the manufacturer here: https://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e . The three dials, from left to right, are thread tension, stitch length, and stitch width (page 9, page 12 of the PDF). See page 24 (page 42 of th ePDF for the pictures of the appearance of the correct tension versus the incorrect top thread tension. For best tension testing, use different color top and bobbin threads. Do use the same thread type and needle appropriate for your fabric and use scrap from that same fabric. In general, if the top thread is visible on the under side of the stitched fabric, increase the tension (turn the dial to a higher number). If the bobbin thread is visible on the top of the fabric, reduce the tension (lower number). Make sure that the machine is properly threaded. (Make sure that the presser foot was up during threading and is raised when you adjust the tension dial.) Start with the tension at 4 and change the tension in small steps. (Do not turn the dial more by 0.5 before stitching a line to test the tension again. You want to avoid over-correcting.) When the tension is correct, the top and bobbin threads will meet between the two layers of fabric for a normal seam.
I hope this helps.
(These steps are the same for any sewing machine with user tension adjustments.)
2answers
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. · .... control the sewing speed by pressing the foot
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Where can I buy an online manual for Bernina Bernette 46
Hi Shiela,
You may want to check this manual I found. Hope it helps.
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
