The fjdr1266w comes on but does not start after pressing the paause and the skip /reset button together while holding them I switch on the fjdr1266w it shows the code E36. It's an anti boiling pressure circuit and I want to locate this fault cos I haven't got a maintenance manuel.
SOURCE: WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
SOURCE: can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
SOURCE: Zanussi FJDR 1466W washing machine,
unscrew water inlet pipe make sure there is water there i know that sounds silly but a lot of self plumbing taps do break down and block or partial block if not this then its the fill valve try tapping it when its switched on obviously again beware live parts use piece of wood or wooden hammer shaft
