Kingston DTSE9H/16GBZ 16GB DataTraveler SE9 USB 2.0 Flash Drive - Champagne DTSE9H/16GBZ Logo
A
Anonymous Posted on Apr 25, 2014
Dtse9h/16gb error code-43 - Kingston DTSE9H/16GBZ 16GB DataTraveler SE9 USB 2.0 Flash Drive - Champagne DTSE9H/16GBZ
How To Fix Error Code -43 Mac ?
If you want to Fix Error Code -43 Mac , follow simple steps https://www.errorcodeexpert.com/how-to-fix-error-code-43-mac/ or call us +1-866-748-5444 for online help for steps by steps guidance.
2answers
How To Fix Windows Errors Code 43?
The Windows error code 43 might be displayed for booting errors. There are detailed solutions proposed in the link below.
Solution - windows Error Code 43 Solution
You have to initiate a startup repair for your Windows OS in order to get rid of error code 43. Another way is to install a fresh windows OS without losing the existing files on your system.
Read here - windows Error Code 43 Solution
2answers
Gt 630 nvidia, error code 43
Update your video card driver at NVidia.com. More current drivers eliminate the conflict caused by having 16GB RAM.
Error code 43
Code 43 is almost ALWAYS a driver problem, not necessarily an external driver, it could even be one of Windows' own. There is a well-written (in my opinion) page at http://pcsupport.about.com/od/errorc/a/code-43-error.htm which discusses the error and how to fix it in simple, step-by-step fashion.
Code 43 errors can be frustrating and time consuming to troubleshoot, but take you time, work it step by step, and best of luck to you.
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
2answers
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
