HP W2007 LCD Monitor Logo
A
Anonymous Posted on Apr 25, 2014
Hp w2007 hpw2007 after flicker display off
3 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 29, 2010
SOURCE: HP w2007, monitor display goes slightly pink in
That can be bad lamps, or bad caps also, but I suspect the lamps.
When lamp gets old it usualy turn on pink and turn white after warm up, but if it is really bad, it will cause the inverter circuits to go into shut down to protect the circuits since bad lamp can draw excessive current. You can see bad lamp album.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Anonymous
  • Posted on Aug 12, 2012
SOURCE: hp w2007 lcd monitor, osd lockout & main menu display
Once you realize that resetting it doesn't work (as I did ) take it apart. This instruction is for an hp w2007 only! It's the one I just fixed. Remove the three screws holding the base on. The one in the middle is hard to see because it's in a hole but readily accessible. Remove the black back cover by inserting a skinny screwdriver between it and the gray housing. Start in the middle on any of the four corners.Pry it up and work your way to the corners. At the corners pry up with more force and the plastic tabs will snap off. Trust me, just do it!! Once you have snapped the plastic tab at all four corners the back will lift right off. locate the three small wires that go into the menu, -, +, select switches. Cut the three wires and tape them off separately. Do this so they can't touch the case or each other. Do to the wires that are going back toward the monitor! The ones going to the switch do not need to be taped. The switches are now dead. Is that clear? Cut the wires going to the switch and tape the cut ends that go back to the monitor. You will no longer be able to manually adjust anything but I never used the adjustments anyhow. The PC will take care of it for you. I did this 8 hours ago and it's still working perfect! Before I made the fix I was getting OSD Lockout, no input signal, it was scrolling through the menu and the screen was going blank every 5 minutes!! It will work!!!
maxcarson
max carson
  • 7627 Answers
  • Posted on Jan 12, 2013
SOURCE: my hp display w2007 has lines that are blurred across all text
Check ALL cables, connections, pins, if you can, reset to default settings on the monitor. Is it under warranty? Any damage? Have you done ANY graphic updates? Hardware upgrades?
My hp w2007 turned blue after I moved it how do I access screen display from the monitor menu
Some monitors change colour if there is damage, internally, within the signal cable. Try another cable if you have one.
Alternatively, it might be that the monitor is near an extremely strong magnetic source, such as big loudspeakers?
My hp display w2007 has lines that are blurred across all text
Can't unintall hpw2007 display software
Try uninstalling it on Safe-mode...
Hope that gives you an idea...
How can i stop my hpw2007 monitor from shutting down automatically? thanks
Right click the background of the monitor, click personalize and see if you have the screen saver on. If you have remove it. Also check the power setting in same screen which would list some option like hibernate, sleep or do nothing. Thanks.
My monitor will not come on after being idle for a period of time
try tapping the space bar key 3X and see if the screen will flicker/ opens. hope this helps
Hp w2007 monitor: Powers on but screen is white - no display at all (no error msg..., just a bright white screen). Blue 'power led' is on. No difference when connected to pc or no connection. Flickers at...
This is an internal problem with the LCD monitor. It is defective and should be returned to the store your purchased it from for a new one. That is the only thing I can really think of if it is not reading properly with a seperate graphics card. It is an internal issue and needs to be repaired.
What is uni mute mean on the hpw2007 model monitor, i used to have sound on this monitor but now for some reason it does not seem to work anymore
Really Uni Mute? is that corect?
I would check your cable going from the PC to the Screen
Its a round cable Green on both ends.
Check to make sure your system is not muted.
Control pannel then sound click unmute
Resolution issue?
Try using the Toshiba graphics control settings instead of Windows graphics control settings to adjust the resolution.
If a cd came with the HP monitor check it for a help file and possibly drivers that optomize its settings.
2answers
BRAND NEW MONITOR OUT OF THE BOX? DRIVER WILL NOT LOAD. DRIVER WONT LOAD FOR HP W2007 WIDE LCD MONITOR (32 BIT) HAVE DISK. (STILL WILL NOT LOAD)
This monitor doesn't need a driver installed. If you can see an image on it, you don't need the driver for it. Windows will install the default monitor driver, and that works for 99.99% of monitors on the market. You need to go into the Display control panel and change your resolution. If the monitor's native resolution isn't available as an option in the control panel, it's because your video card can't display it, not the monitor's fault.
My hp w2007 monitor has no sound.
my hp w2007 monitor has no sound
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
