Because forget the password
SOURCE: forget wireless-G broadband router, how do I change it
There is a reset button in the back, small pin hole, hold it in for 10 seconds.
This will restore it to when it was new so you will have to reset all your settings.
The user will be- admin and the password -linksys
or check your manual if these don't work.
SOURCE: i forget login password of router
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router. After a hard reset, every router returns to default factory settings.
See: how to perform hard reset
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Click "Apply Changes". Your new password is now
active.
Do
not forget the new password and keep it somewhere safe.
If you forget your password, you'll be unable to access your router's
settings. If you forget or lose your password, you'll need to perform a hardware reset on the router. This will reset the password to
its default, as well as erase any
and all other settings you may have changed.
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "restore to factory default". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Use a strong alphanumerical (letters/numbers) password.
Setup steps:
Setup steps:
