Planar 42" Touch Pd420ti Lcd Monitor Logo
A
Anonymous Posted on Apr 24, 2014
Pd420ti no button - Planar 42" Touch Pd420ti Lcd Monitor
1helpful
PLEASE I USE IRULU BUT I WAS TRYING TO REINSTALL IT BE IT WENT OFF NOW HAVE CHARGE THE PAD BUT HARD TO REINSTALL PLEASE HELP.
You need to fully charge the tablet and THEN do a factory reset. The hardest part is waiting.
Follow the steps provided below to perform a Hard Reset on your iRULU Android Tablet:
  1. Turn your iRULU tablet off.
  2. Press and hold the correct key combinationto boot your Android tablet into Recovery Mode.combinations, which include:
  • Home button + Volume Down button + Power button
  • Power button + Volume Down button
  • Power button + Home button + Volume Up button
  • Power button + Volume Up button
  • Power button + Volume Up button + Volume Down button
  1. Release the power buttons once your screen turns on, and the device vibrates. Keep holding the other buttons for 10 seconds.
  2. Your Tablet should now boot into Recovery Mode.
  3. Scroll down to the 'Factory Reset' option using the volume down key.
  4. Select the 'Factory reset' option by pressing the power button.
  5. Now your Tablet will start the hard resetting process.
Once the process begins DO NOT press any buttons and don't try to turn the device off.
Your tablet should now be reset.
How to factory rest memorex blu ray dvd player modle MVBD2520
Hello
Select the General menu. Select
RESTORE SETTINGS using the Navigation ( UP or DN) buttons (1),
, then press the ENTER button (2). Select YES using the
Navigation (Up / Dn) buttons 1 and press the ENTER button 2
again to restore the settings. Select NO to leave the settings
as they are.
WHERE CAN I DOWNLOAD A COPY OF THE NASCAR 07 INSTUCTION MANUAL?
I couldn't find a downloadable copy but got a hand written one:
NASCAR 07
RACING CONTROLS
Directional Buttons Steering
X Button Share Draft
Triangle Button Reverse
Square Button Intimidator
Circle Button Change View
L2 Button Brake
L1 Button Shift Down
R2 Button Accelerate
R1 Button Shift Up
Start Button Pause
Select Button Toggle Mirror
Left analog stick (L3 Button when pressed down) Steering
Right analog stick (R3 Button when pressed down) Team Communicator
Printer error fuser temp in xerox
Hi kazm_atkli, check this out:
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
I hope i helped you! Ifyou liked me please rate!
5helpful
ERROR 5B00, no me deja imprimir
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume" (red circle in the triangle) and push "Power" button.
3. When printer become ready hold the button "Power" and release button "Resume".
4. Push button "Resume" 2 times and then hold "Resume" and release "Power" button.
5. When I hold button "Resume" I push and hold "Power" button and release "Resume".
6. When I hold "Power" button, push button "Resume" 2 times and release both buttons.
7. When printer become ready on the display write "CANON Idle".
8. Push button "Resume" 4 times.
9. Then push "Power" button 3 times to turn off printer.
All done. The printer is ready to print.
1helpful
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
6helpful
Instructions for super nintendo games on the intrenet
Here is the controller instructions for "John Madden Football"
CONTROLS KICK OFF Y Button call onside kick formation B Button kickoff, activate closest defender A Button call audible RECEIVING ONSIDE KICK Y Button attempt to receive kick on the left side of the field B Button attempt to receive kick in the center of the field A Button call audible, attempt to receive kick on the right side of the field OFFENSE BEFORE THE SNAP X Button fake snap B Button hike ball A Button call audible OFFENSIVE AUDIBLES X Button cancel audible Y Button running play B Button anti-blitz play A Button trick play OFFENSE AFTER THE SNAP Y Button dive B Button break tackles A Button spin PASSING X Button pass to receiver in window x Y Button pass to receiver in window y B Button show passing windows, pass to receiver in window x A Button pass to receiver in window a RECEIVING, RUNNING X Button reach for catch Y Button dive B Button break tackle A Button spin DEFENSE BEFORE THE SNAP B Button activate defender A Button call audible L or R Button line surge DEFENSIVE AUDIBLES X Button cancel audible Y Button stunt B Button blitz A Button defend against run DEFENSE AFTER SNAP X Button reach Y Button dive B Button activate defender nearest the ball A Button power tacklehttp://www.allgame.com/game.php?id=2510&tab=controls
Help dont want to lose everything
The reason it is asking you if you want to delete all is because you have not selected specific files to erase, so when you hit erase without selecting a file it assumes you mean delete all.
To erase try these steps...
To erase a selected file from Folder A, B, or C:
  1. Press the MENU/FOLDER button to select Folder A, B, or C.
  2. Press the - or + button to select the file to be erased.
  3. Press the ERASE button.
  4. Press the - or + button to select YES.
  5. Press the ENTER/INDEX button.
To erase the contents of Folder A, B, or C:
  2. Press the ERASE button twice.
  3. Press the - or + button to select YES.
  4. Press the ENTER/INDEX button.
To erase a selected file from a date subfolder in Folder S:
  1. Press the MENU/FOLDER button to select Folder S.
  2. Press the - or + button to select the date subfolder.
  3. Press the PLAY button.
  4. Press the - or + button to select the file to be erased.
  5. Press the STOP button.
  6. Press the ERASE button.Press the - or + button to select YES.
  7. Press the ENTER/INDEX button.
To erase the contents of a date subfolder in Folder S:
  2. Press the - or + button to select the date subfolder to be erased.
  3. Press the ERASE button twice.
To erase the contents of a month subfolder in Folder S:
  2. Press the ERASE button three times.
  3. Press the STOP or PLAY button to select the month subfolder to be erased.
  5. Press the - or + button to select YES.
  6. Press the ENTER/INDEX button.
To erase the contents of Folder S:
  2. Press the ERASE button four times.
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
