SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: Turns itself off
Sharp LC-13AV4U - turn it on and in ten seconds it turns off.
Happens every time.
Any Ideas?
DO THIS AT YOUR OWN RISK!
This is NOT a fix, this is a permanent band-aid.
All you need is a phillips head and tiny diagonal cutters....
Heck, even a nail clipper would do it.
Just disable that faulty protection shut-down circuit!
Remove all the screws from the back cover
and look at the main board with the
unplugged! power cord towards you.
In the upper right corner of the board, you will find
a tiny red-striped zener diode, labeled as D409.
It is to the right of an electrolytic capacitor marked C403.
Snip this diode, at either end, or snip both ends and discard it.
Re-assemble the TV.....and you just got your tv back!.
I only run mine when I am sitting in front of it,
I never leave it running unattended....just in case!
Don't blame me it yours burns up....but mine is just fine.
The Robot Doctor.
SOURCE: Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
