Whirlpool lsq8500jq1 washer works and spins but wont stay balanced, except when empty. I have balanced the load, 2 towels, it starts spinning the goes out of balance.
Hi Paul, first piece of advice is to make sure the loads of laundry are consistent. A pair of jeans or a bath towel in a load of lighter clothes can cause an off balance condition, causing the machine to constantly try to re balance the load and never reaching high speed spin. Other than that,make sure your spin speed option is set to high. If those don't solve the issue,contact a local repair company to come out and take a look. Hope that helps.
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
with a lot of the machines now they wont go into spin mode if the drum is not balanced properly, like say you had a load of towels in their, well it wont spin as its to unstable to spin without wobbling around so it simply stops at the spin cycle and does nothing, you can try this by turning it on with no clothes in and see if it will go into the spin cycle with no clothes in, if it does then chances are its not weighing the clothes properly and would end up costing a fortune to put right as it sounds like you spent a lot of money on parts all ready, so give i a try with no clothes in and see if it will spin, have you tried turning the drum by hand when its switched off to check for any grinding noises or jerking when you try to turn it by hand, im not sure how the balance sensor works or even where it is as its a new feature in the last few years but people are now starting to have problems with this feature and it stops the machine from spinning leaving the clothes soaking yet, so give it a try empty and see what happens
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
from the description you are giving, i would guess that: 1. the "coin-catcher" ahead of the pump is plugged. 2. the tub is overloaded. 3. the loads are heavy, bulky [ blankets, jeans, towels]. when a load is too big or it is all very absorbent materials, the machine tries to balance the load before it goes into a final spin, it will not spin on high if it cannot balance - remember, ten towels or pairs of jeans soaked with water is darned heavy - mix the loads i'm familiar with this machine because i have one, i repair washers and dryers as part of my job, in my opinion, the duet is the best and most reliable washer available
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
