Garden Logo
Posted on Jun 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a troy built pressure washer and the gas is leaking out help
Have a 2 yr old troy built pressure washer 2550 have only used twice...the first two times the hose split right open...just got another new hose and going to use it and the gas is leaking out of it...help
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Jun 20, 2009
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
380776
Points
3221
The float is stuck you can either take it apart and clean it or you might get by by just tapping lightly on the fuel bowl on the bottom of the carburator to unstick the float
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
4helpful
Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
17helpful
3answers
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Top Garden Experts
Jay Finke
Jay Finke
john h
