I recommend using automotive "anti-seize" compound, a high-heat, metallic paste, typically applied with a small brush during the assembly or installation of car parts subject to extreme heat, so they don't seize or fuse together over time. If there is access to the "squeaky part" of the stove's hinge, slathering it with some anti-seize should keep it quiet for a long while.
Thank you for your post, friend!
I see that you need assistance in repairing a squeaky door on your Frigidaire dishwasher. The best way to quiet down a squeaky door is to pinpoint the cause of the squeak. This could be an issue with your hinges, springs, or the cables. You can use a lubricant such as WD-40 on your those parts to see if that will help alleviate the squeaking. Hope this is helpful. -Matt
