nature answer fenugreek gynecomastia, fenugreek muscle, induce lactation fenugreek Logo
A
Anonymous Posted on Apr 24, 2014
Why are my nipples white - nature answer fenugreek gynecomastia, fenugreek muscle, induce lactation fenugreek
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Jan 28, 2015
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
992055
Points
5072
Vasospasm. low blood flow. go get them warm
Where is fuel filter located on 88 mazda 323 manual hatchback
Your fuel filter is located on the left side of the engine compartment. It w\should be off white in color, plastic cylinder with an In nipple and an Out nipple with rubber hose attached on each nipple.
I have a husqvarna 345 that has a primer the line from the primer has come off at the tank and I see there are two ****** Does it go on the inserted white nipple or on the built in orange nipple?
OK, the white connection is the tank breather so do not put the pipe on here, the orange connection is the return to tank so this is where the pipe goes, hope this helps.
2answers
Briggs/Strat mower. Wont prime. White plastic nipple on side of carb w/ nothing attached. Shud there be a priming fuel line from this nipple 2 gas tank? Cant find diagram or 2nd attachment on tank
Nobody still hasn't answered your question, I'm curious too. I can't get it to start and I know that empty
nipple has something to do with it. Does anyone have a working hyper tough briggs mower that will start and has a nipple to the right of the carb with no line on it??
Mar 17, 2018 • Garden
2answers
Have squeak coming near front axle on passenger side
on what that would really help, check brakes
Gas lid won't close
TRY SPRAYING WD-40 ON THE NIPPLE AND WORK IT BACK AND FORTH
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
I have model 345 and the nylon nipple on the fuel tank trturn line system leaks when the tank is full. Saw was dropped once with no apparent damage Can this nipple be replaced?
If this is the orange plastic conection that the return hose conects to, then no it cannot be replaced, it will be a new fuel tank, if it is the white conection next to the orange one, then this is the tank breather, and can be pulled out and replaced.
1helpful
5answers
I recently took apart the climate control module on my 1985 Winnebago motor home (GMC chasis & drive train). I determined that the reason I was not getting heat or A/C was because the vacuum tubes...
The exact connection of vacuum tubes in 1985 Winnebago motor home
The vacuum lines attach to the pushbutton assy. through a molded rubber thing that has probably disintegrated and the vacuum lines are lying loose. Here's how to reconnect them.
Notice a group of seven nipples. This is where the vacuum lines attach. I numbered the nipples in the text drawing below. NOTE: This is the layout as viewed from the front of the coach. Use pieces of rubber tubing to take the place of the old molded thingy and connect the lines to the numbered nipples as described below.
1 2 3 4
o o o o
o o o
5 6 7
Plug up nipples 1, 2, and 5.You can use  small nails that fit snugly into the holes.
Connect the black line (vacuum source) to nipple 6.
Connect the white line (rearward-pointing outlets) to nipple 4.
Connect the red line (downward-pointing outlets) to nipple 7.
Connect the blue line (heater) to nipple 3.
Check out.Thanks.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
1helpful
2answers
I have a hot water heater,for some reason it started leaking were the cold water goes in, it was leaking were the round white cover that cover the whole that the connection goes in the tank.Can you tell me...
To find out you need to cut away the white cover to see where the leak is coming from. This white cover is just cosmetic.
If the leak is on the connection where the supply line comes in, then is usually can be fixed.
If the leak is on the metal of the tank below the connection, then there is no fixing it. The metal just below the white plastic is part of the tank.
If the leak is on the connection, it can all be replaced. I recommend replacing the nipple going into the water heater with a 3/4" x 3" brass nipple. From there I recommend using a 3/4" x 3/4" x 18"-24" copper water heater flex. This assuming that you have a flex line installed now. If not I still recommend the brass nipple and the copper flex, but you can get a 3/4" Sharkbite Male adapter to adapt to copper pipe. (Use this fitting instead of having to solder. This fitting is found at Home Depot and Lowes. Be sure not to have any burrs on the copper pipe, because Sharkbites use an O'ring which can be damaged by any burrs.)
If you have a different plumbing installation, please contact me.
Please Rate this solution
Top nature answer Cooking Experts
ADMIN Andrew
ADMIN Andrew
Billie Aukuso
Are you a nature answer Cooking Expert? Answer questions, earn points and help others
