SOURCE: HP Officejet Pro L7580
scotti444 ,
hi! try this solution for your problem.tnx
Follow these steps to correct the problem:
Figure 1: Destination tab of the Button Settings
5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
6. Click OK to save the changes and exit the setting.
Causes:
>This error message occurs if the Scan To settings have never been set.
hope this can help you resolved your problem
regards,
coffeebeans
Refer to this link the will help you to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&lang=en&product=2512008
SOURCE: "Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
SOURCE: When I try to scan, it reads "No Scan Options".
Try scanning from the solution center. If successful, check the scan button settings if you can see applications available on the 'Destination List'. Add all the application to the right side. Close the solution center and try to scan.
SOURCE: HP OFFICEJET PRO L7580 PRINTER WILL NOT RECEIVE FAX
Is the machine set to auto receive?
Try unplugging the power for a few seconds. This may clear any data that is "log jamming" the memory.
