Bowflex Treadmill Series 7 Logo
Anonymous Posted on Jun 20, 2009
MESSAGE "ERROR SPEED STALL" KEEPS COMING UP
We just purchased a new Free Spirit treadmill, but there was no manual, we keep getting the above message. The treadmill goes up an down but the track never moves. How do we fix this problem.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1121
Points
Returned the machine and got our money back, thanks.
Anonymous
Level 1:
New Friend:
  • Posted on Jan 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1121
Points
Stupid website sign in no solution what for
I have a spirit treadmill machine model ct800 since last the machine is shown Low Speed error. Please suggest me what to do
When do you get the message? In the middle of a workout or right when you start he machine? Does the belt move at all before you get the message?
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
Free spirit club FS200
Could be that the belt has stretched and it needs to be retightened or replaced with new one.
2answers
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Error E1 on star trak treadmill
please test the speed sensor. see the diagram attached .This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board test the output voltage for input voltage terminal power if there are NOT the board is faulty . The error codes will differ between makes and models but could be e1.
See my personal TIPS for help.
2answers
Error message "Speed Stall" stops will not run. :(
You must try a) LUBE very well the Deck belt and walking belt b) Recalibrate the machine.
If after this situation persist.
You must replace the EPROM(software is coming inside, and can be corrupt), call to the company.
for to get it.
Blessing.
How To Lubricate Treadmill
[email protected]
cell+whatsAPP:+50588611441
Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
12helpful
3answers
New free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Top Bowflex Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
