Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP)
exclusion list. This error is comming because you have enabled DEP. I
think it will help you to fix the issue. Thanks for joining Fixya community...Good Luck
As time goes on software applications tend to change enough that an older version produced file is not forward compatible with a new version. For instance some of my MS Office files no longer can be opened by the latestr version of "Word", hence Microsoft issued a plug in that will allow you older "Doc " files to be read by the latest version of "Word", same thing holds tru for FLASH program, every time a new version of FLASH comes out, the older version can not be read by it.
You need a version of QuarkXpress that can read this doc, If you created the original document, the you can go to your version of QuarkXpress to open the document or if possible ask the originator of the document what version they used to create the document.
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
In case of a Windows machine Navigate to C Drive>>Program files>>QuarkXPress folder and create a new folder by the name Preferences with P in upper case.
For Mac HDD>>Applications>>QuarkXPress folder and create a new folder by the name Preferences with P in upper case.
Just downsave the project by going to File>>Export layout as project and choose the version as QuarkXPress 5. once done open in QuarkXPress 6 and save it
Do a recovery at boot up. You are missing files for some reason. IE can't find what it needs. Either some kind of virus got it or you have a programming error. Do a Recovery at boot up. Immediately after the recovery, scan for viruses.
