How to remove engine
Depends on what pulley you are referring to. The bottom pulley is held in place by a large nut, the pulley has a key way to keep it from spinning. Sometimes this keyway will shear off if you hit something with the mower. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Fig. Fig. 12: To remove the serpentine belt from the 3.3L and 3.8L engines, rotate the tensioner assembly clockwise
Fig. Power steering pump mounting-3.1L and 3.4L (VIN E) engines
