I am unable to select e-mail in SCAN. Keeps saying 'Check email parameter settings.' Any idea what it is looking for?
You need to go into the options and configure the email settings.
You need the server details to send an email with so most likely what happened is whatever settings it had are no longer valid.
Use your own email like gmail or live mail and get the server setting from one of those websites. The printer/scanner will likely support sending via POP mail or SMTP. Your email provider will have the instructions for this.
If you have a hard time navigating the menu system on the printer, just download the manual. It's a Panasonic yea? So it should be easy to grap the manual.
SOURCE: Scanning to EMAIL on Panasonic DP-C322
Incorrect SMTP Server IP Address is
set.
No email application is activated on the
Mail Server
SOURCE: How can I set up email addresses and save them for
yep!
first you must have smtp server (for sending email)
and pop server (for receiving email) running on your
network.
second, turn-off you dns settings and set all network
parameters as IP Address (host, smtp server, and
pop server ip address)
that's it!
SOURCE: How do I reset the
never knew these things had a password to be honest ,try calling the service department of the manufacturer because if its a office version then yes it will have a password to stop unauthorised use of machine out of hours and if you have a secondhand one -?- phone them and ask ,is their a service number on the side of the machine ?'
SOURCE: Panasonic dp-c322, "replace black toner"
This model estimates toner usage based on dot count.
You can reset the counter by pressing "function" key, then counter view. Scroll down near the end and you will find toner counter reset. Select "k".
SOURCE: How to scan
My dp 2330 copier prints dark shades(0.5 thick dark lines) even though the text you want to print is seen in the back ground. pls what should i do or whats the problem? Thank you .
