SOURCE: Iriver x20 - freezes and wont show as a connected device to pc
When you connect the PMP to the computer does it say your new device is ready for use or something else like 'the device has malfunctioned'?
I have the same issue that frequently the computer won't see the PMP. Keep trying it sometimes works. If not then its likely that the harddisk is dead or dying.
SOURCE: How do i add album art to iriver x20?
if your using wmp11 you should just be able to drag and drop.
if not right click the song/album and go to advanced tag editor, pictures and then add manually.
half the time it just wont come up because the tag doesn't read properly and the other half the album art that wmp11 downloads and applys automatically will come up!
its kind of up to chance! if you're lucky it works if not live with it its the X20!
ps the iriver plus 3 and itunes also can apply album art
SOURCE: iRiver X20 not reading SD card
yes this is correct, you can only have the same size memory card as what your iriver was originally. eg when I bought mine it was a 2GB so there for I could only add a 2GB memory card in it giving me a total of 4GB. if you buy a SD card of the same GB you wont have a problem
SOURCE: iriver X20
can you connect it to your computer?
if so then format it then run iriver plus 3
plug it into the computer
then go to tools>Portable Device>Disk Initialization
if you cannot connect your x20 to your computer
there is a tutorial on the iriver support page saying you can format it by,
holding down menu butting and turning it on
but that didnt work for me..
otherwise, its stuffed..
if its stuffed, dont throw it away, ill buy it off you..
contact me if your interested, [email protected]
