Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Hi
This Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
Hi
F3-E2 Error indicates
Daniel
Hi
This indicates a
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
Hi
This means a
Daniel
Hi
F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Hi
This means a
Daniel
