Cooktops Logo
Posted on Apr 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my thermador cooktop shuts itself off ?
The burners in my thermador cooktop lit up fine but then they turn themselves off. The cooktop is connected to a LP tank.
rayreidblack
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 117 Answers
  • Posted on May 10, 2014
rayreidblack
Expert
Level 2:
New Friend:
Cheetah:
Answers
117
Questions
Helped
42040
Points
129
Has it been smelling of gas recently? That usually indicates your lp gas cylinder is almost empty.
Ray
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 30, 2007
SOURCE: Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Anonymous
  • 130 Answers
  • Posted on Aug 09, 2008
SOURCE: Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Anonymous
  • 324 Answers
  • Posted on Nov 15, 2008
SOURCE: Need to convert a Thermador cooktop from Natural to LP
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1048620&PPStack=1
try this link.
do not drill out the jets they will not work properly.
I would check all your documentation you may have the convention kit with your owners manual or it may be attached to the oven.
Anonymous
  • Posted on Jan 25, 2009
SOURCE: Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: One of the igniters on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ertwr
Thermador induction cooktop CIT304E error code U 24
Question moved form Water Heaters to Thermador Cooktop
There is an F24, but not a U24
F24 Touch input key stuck Replace power relay board, and touch panel
https://www.google.com/search?q=Thermador+induction+cooktop+error+code+U+24
Two burners on thermador cook top turn off by themselves
It is common for electric coils on a range top to click/on/off. They are suppose to reach a certain heating range and when satisfied, they go neutral and when the demand for heat is needed, they become energized again.
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
3helpful
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
1helpful
2answers
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Ignitors Continue to Spark
Turn the knob back towards off about 1/8 of a turn and you will take it off lite and it should fix it.
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
