Display flashes every 5 seconds, but will not stay on
SOURCE: since change over to digital dvd/vcr Toshiba
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
5 seconds, you will have to start step 3 over again.
7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will
increase continuously. Release when the display shows the Stride Length for you.
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
