If I put it to sleep and try to restart it won't come to life I have to pull the power plug and plug it back in again
SOURCE: computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
SOURCE: Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
SOURCE: HP Pavillion dv6000 once in sleep mode, won't wake up/crashes
Yeah I can understand. I must assist by telling you that you can configure these settings by using POWER SETTINGS application which you can find in your CONTROL panel.
Your all confusions and doubts will be clarified by that application and then you will have to reboot system manually. You can choose configuration for your best personal use.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
SOURCE: laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
SOURCE: Acer aspire one, won't wake up from sleep mode, screen blank
I'm having the same problem, but I don't want to have to turn off my computer EVERY time it does this. (I have not been able to shut down the laptop normally because it goes into sleep every time.) I've heard that after 3 hours it builds up an eletrical charge and you have to take the battery out, but I havn't had it on for 3 hours at a time.
