Change system boot order in system bios, no f12 key did not do anything
SOURCE: emachine boots to bios with a new hard drive installed
well your jumper is probably set to boot right to bios. you have to go into your comp and move the jumper to its origional location.
SOURCE: Emachine T5224
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
SOURCE: emachine T5212 will not boot up unless operating
Restart, press DEL to enter BIOS and change the boot priority/sequence to boot from your HDD, second choice will be from CD-ROM and last from floppy. Next after saving the changes allow it to boot normally....sodeep.
SOURCE: i am trying to change my boot order on my emachine
instead of hitting the tab key, i would try hitting the F8 key, this one should get you into your bios. From there you should be able to go into your boot options (or startup) and you should be able to select using the arrow keys and the + - keys to change your preferred boot option//
SOURCE: Thinkcentrre 8143 can't change bios
The f10 is usually the save and exit or exit options key. Your particular version of BIOS should tell you in one corner of the screen.
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
