Mitsubishi WS-65511 65" Rear Projection Television Logo
Posted on Apr 24, 2014
Why does it keep turning off?
When you turn it on it shuts off in about 2 seconds. won't stay on!
1 Related Answer
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Feb 04, 2008
SOURCE: Turning on for 2 seconds then shutting off
thats the protection circuit. it detects that the low and or high voltage is not correct and shuts down.
you need a tech .
My 3M Transparency machine won't shut off
No, machine keeps running, but lamp is out. This is cool down cycle. Dont turn it off. It will vary from 15 seconds up to 2 minutes. This is pretty normal.
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
1helpful
Vizio e320vl stays onm for 2 seconds and shuts off i have replaced main board and power supply what can i do next?
did you use the same RAM-memory on the second main-board ?try different ram memory, it might solfe your problem.
If it does, your first main-board whill be okay to.
please keep me informed.
Bart
1helpful
2answers
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
3helpful
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Power keeps surging and won't stay on
I will need the model number of your set in order to make any suggestions as to what possibly could be causeing the problem
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
