SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
SOURCE: SAFEGUARD MODE
The most common problem is that the belt for the center pulley comes off. The best fix is to replace the center pully because it is out of tolerance allowing the belt to jump off. Do you have an E03 error code on the screen? This is not a simple repair. The sequence involves a total disassembly, removal of the main board, removal of the mechanism, removal of the mechanism board and cassette-up basket, replacing the center pulley, reinstalling the belt and entire reassembly in reverse order. If you haven't done it before, even as a pro, you're in for a treat...Good luck, magic seadog
SOURCE: safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
