Hello, the unit is a 3 ton and was built in 2004. 0z R22 stands for R-22 refrigerant. Not sure why he told you 410a but if the unit says R-22 than that must be used.
R 22 will intoxicate the system due to different compatibilities with lubricant. The 407 uses Ester and 22 mineral oil. R22 in a Esters oil environment may cause gunk. Install proper labeling indicating loud and clear that the system is not R22 for future reference. You know what needs to be done.
If it has enough freon to freeze up then its not that low. Normally a 4-5 ton cooling only (non heatpump) will hold 7-9 lbs r-22 or 9-11 r-410a. Freezing can be caused by dirty air entering side of the coil also. Or slow blower
If he only added R-22 for 5 seconds, then no, it did not take 2 lbs. Even if this was possible, the R-22 being upside down, (meaning it was charged in a liquid state), it would flood the compressor and more than likely cause damage. Now, it does not take long to add 2 lbs, charging with liquid, but almost impossible in 5 seconds with refrigerant already in the system. Sorry to hear about your situation, unfortunately I hear this same scenario far too often.
Hello TF YES to make ice on low freon you lost more than 1/2 of the factory/system charge.4 lbs is about rite.I would like to find the freon leak as you will always have to replace the gas every now & again untill found & repaired.
