Motorola MC9190-GST Logo
A
Anonymous Posted on Apr 23, 2014
Connect to desktop - Motorola MC9190-GST
Kelly
Level 2:
Habit-Forming:
New Friend:
  • Motorola Expert 60 Answers
  • Posted on May 04, 2016
Kelly
Motorola Expert
Level 2:
Habit-Forming:
New Friend:
Answers
60
Questions
0
Helped
75619
Points
287
To connect to a desktop you will nee to download Activesync (win XP) or Windows Mobile Device Center (Win 7 and above).
Tech Support Barcoding Technical Support
  • Official Brand Answer 3,100 Answers
  • Posted on Jan 08, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684186
Points
13487
Contact Zebra Technologies Support Downloads or Motorola Solutions Get Support
Mark
Motorola Mobility Support
Dell Optiplex 745 desktop will not connect to internet
Most desktops need to be connected with a wire to your network because most desktop computers do not come with a wireless NIC (network interface card). If you are not sure if yours has one you can get your service tag off of your computer and type it in the Dell website (link below) under drivers and downloads and look at the original configuration for your system. If you have a Wireless NIC card in your desktop it should connect just like your laptop computers did. If not you may have a defective wireless card.
Dell Website
tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 • Computers & Internet
When i turn on my screen it says no signal and turns off
Either the "data" cable between your screen and your desktop is defective, or that cable is not connected to your screen, or that cable is not connected to your desktop, or the video-card inside the computer is defective.
Check the connections.
Temporarily connect the screen to a different laptop/desktop computer, to see if the screen still works.
Temporarily connect a different screen to your desktop, to see if your desktop's video-adapter is working.
Not connecting with desktop manager
Download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8220 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=702BB8A8D212AB863750ABA38D5103B0
Just fill out the form and the download is free.
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Connecting desktop and laptop to a wireless router
I have the same problem. Startign this morning, when I connect modem directly to desktop, it works. But when I connect modem to this router and then connect to desktop, nothings works.
again - if connect modem back to desktop directly, then it works!.
what is the issue.....? not able to figure it out.
I did reset, change router IP etc etc everything nothing resolves the core issue!
Limited Connectivity
connection is to the router not the desktop pc
Ignore the desktop pc
check the wireless security settings in the unnamed router and make certain that the non-connecting laptop has the same settings.
Remote desktop connection
It sounds like you had a pre-release version of RDC 6.1 installed which you should have uninstalled before installing SP3.
Check this out - under "Remote Desktop Connection" you might find the solution you're looking for.
http://download.microsoft.com/download/c/d/8/cd8cc719-7d5a-40d3-a802-e4057aa8c631/relnotes.htm
Hope this helps! : )
One card interfering with other connections
Have you checked to make sure the laptop wireless NIC isn't acting as an AP by mistake? That could explain both desktop and laptop connectivity issues. Just a thought.
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
