WHEN YOU TURN IT ON, IT SHUTS OFF IN ABOUT 2 SECONDS
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
SOURCE: Turning on for 2 seconds then shutting off
thats the protection circuit. it detects that the low and or high voltage is not correct and shuts down.
you need a tech .
I don't know if its rear projection or not the computer automatically put the words after I typed in model number
