Was working fine but I added a wd essentials external hd directly connected to the pc and did a data backup - the next day usb thumbnail drives did not work in the hub but did so if directly attached to the pc
SOURCE: External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
SOURCE: Disappearing files from Hard Drives
find if you portable deviceshas any SAFETY REMOVE function, if you using hot plyg and unplyg function without firs safety remove it causes this action, same is in flash drives. because writting process is not finished when unplug and last transaction had not been writen and file allocation table has wrong data in it.
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
SOURCE: Belkin 7 Port Hub has power (red light is on). Has
unplug port and plug port back in and then restart computer.
