Bunn nhb leaking when brewing
Most likely is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
SOURCE: HAVE BUNN NHB COFFEE NOT HOT ENOUGH ON BREWING
I work for BUNN. Please call our customer service team at 800-352-2866 so they can talk thru what's going on and solve this for you.
SOURCE: My Bunn coffeemaker NHB is leaking from the bottom
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
SOURCE: Unable to remove our sprayhead from our Bunn NHB Coffeemaker
You might try putting a butter knife underneath the sprayhead to remove it. If this doesn't work, then please contact customer service and request a tool that can be provided to remove the sprayhead.
SOURCE: My NHB bunns coffee maker
If you will call Customer Service at 800-352-2866 with the model and code date, we will be able to help you resolve this issue.
SOURCE: Bunn NHB model leaks water
Please call customer service at 800-352-2866 with the date code from the bottom of your brewer. We will be happy to assist you with this issue.
