I have a maytag dryer/washer combo (Dryer Model # LSG7804AAE Clothes Washer Serial # 16211326QH). When I switch on it fills with water but then everything stops. Please assist if you can
Thats sound like it may be a bad lid switch. To check that TURN OFF THE CIRCUIT BREAKER OR UNPLUG remove the front panel off washer and then the washer can be pulled out and away from the dryer. inside in the corners upper corners will be two 3/8th inch bolts that hold down top to cabinet. Remove those bolts , oh im skipping ahead firts remove the two 5/16th inch screws on the back right side of washer top.After removing screws (5/16") and bolts (3/8") that hold top lift up top the lid switch asm. is there under the top where the 5/16" screws were removed partially pull out that asm and be sure to remove the tab that slips into the underside of the top for switch asm. then remove switch asm. so switchs insicde can be accessed. Use a multimeter and check switchs when lid closed for continuty. the big one should have continuty when lid is closed and the small one should have continuty when lid open.
If it turns out to be either one that is bad replace the switch asm. asa entire piece the part number for that switch asm. is 12001513 it will also come with a fuse replace that fuse too,it goes on the fuse holder on left side of cabinet side panel(if fuse were bad now it would not fill) the part can be picked up from yoor local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
midwestapplianceparts.com
Good luck,i hope i have been able to help you fix your washer,
Gene
