How to change the brushes on a dewalt 825 impact
SOURCE: I am looking for a carbon brush housing
You can buy at Nappa auto parts stores. Please rate as this is a short answer and if you don't rate it it hurts me.
SOURCE: Oiling a Sears 900.275132 impact wrench
use air tool oil and put a couple of drops where the air plugs in.
SOURCE: how do I lubricate my
Its newmatic right just put a few drops oil right down the air feed and a moisture trap inline off the compresser would be goodHowever the picture looks like its electric and you don't realy have to do that now its prelubed and shouldn't be an issue for many hours of service. If it is air then wd 40 works fine the problem comes in when they sit with out use for long peirods of time they rust and seize and thats hard to fix
SOURCE: milwaukee 18volt impact wrench has no power
i have the same impact an replaced trigger switch. i think it was 38,00, had the same thing happen with my de walt xp hammer drill.U can check switch continuity before replacing
A good place to start with Dewalt tools is the switch. Take the front off the handle and pull the switch out far enough to test the posts on the back. Plug the cord in and check for voltage where the cord attaches to the switch. No voltage, bad cord, replace the cord. If you have voltage, the cord is good. With some help, hold the switch on and check for current on the motor side of the switch. If no voltage, replace the switch. If there is voltage there, you are going to have to check the brushes, armature and/or field for continuity or shorts.
