Panasonic Advanced Hybrid Kx-t7730 White 12 Button Spea Logo
A
Anonymous Posted on Apr 23, 2014
Change my phone name - Panasonic Advanced Hybrid Kx-t7730 White 12 Button Spea
1helpful
I can't changed name on my phone. please help me.
The extension names can be changed in admin programming from a predesignated programming phone. Typically this phone is the attendant phone as in ext 100 or ext 101.This phone needs to have an LCD screen.
1) Press <program>
2) Dial **1234(1234 is the default admin password)
3) Dial 004 for Ext name programming
4) Press <enter>
5) Dial extension number that you want to change name of as in 102
6) Enter name (20 characters or less )
7) Press <enter> to store
8) Press <end> or lift handset and return to cradle to end programming session
Change name of phone
go menu and settings and go to display settings and change it
Changing the name of user on panasonic phone
Press program *# and your system password (default is 1234). Enter 604 then press SP-PHONE. Keep on pressing SP-PHONE until you get to the desired extension number. Change the name and press AUTO DIAL / STORE. Press program to leave programming mode and you are done.
How to change the names on the phones?
You will need access to the phone system "Telephone directory" form this can be done by your system administrator, or your phone vendor.
1helpful
Is there anyway to change the name that is
It's part of the phone system, it's software. Find out who controls the phone system and get your name on it.
1helpful
Name Display
The voicemail name and the phone system name come from two different places. Your system manager should be able to reprogram the phone system to change names.
Carl
How do I change the display name on incoming line
You would have to go into program mode.
program 93-1 would do the trick.
Tony
Ameritel
732.477.7733
8helpful
3answers
Change name of 1 extn
Without picking up the handset, press program *# 1234. 003. keeping pressing the speaker phone until the extn u want to change is displayed. Note down the jack no.
Then press hold and 004. Then press speaker phone 1 time and enter the jack no of the extension whose name has to be changed. then change the name. After you finish entering the name press autodial.
5helpful
Changing time (ie. clock) and changing names of lines
Hi Michelle,
To change the time you need to press the 'Prog' button, then press the * key twice, so '**' then enter '1234' then enter '000' then press the 'enter' button (located bottom right hand corner of phone) and this will allow you to change time accordingly.
To change extension name, press 'Prog' button, then press the * key twice (as above), then enter '1234' then enter '000', then enter '004' then press 'enter' button (as above), this should then get you to the spot where you can change the name.
Cheers
AngelXena
8helpful
4answers
Changing the names on extensions
Fuction
266344
Pw: 23646
Terninals & Sets
Show set: (type your extension in)
Your extenstion shows: Your Name or Name You want to Change
press top right Arrow button
Capabilities...
Bottom right Arrow button
Name:
CLR Change
Press Change, then use the keypad to type in new name
Prees bottom Arrow Button again, then Release button.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
