ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Acceptable Paper Weights
Cassettes: 17 lb. Bond to 110 lb. Index
(64gsm - 209gsm) and Transparency
Stack Bypass: 17 lb. Bond to 140 lb. Index
(64gsm - 253gsm) and Transparency
Hi, in order to activate the double count for A3 paper, you have to go into "special" SP mode. The procedure is almost the same as going into regular SP mode, but as you hit "Copy SP" on the touch screen, make sure you are holding down the pound (#) key. Then you should be able to find 5104.
You can only change 5104 once, so one you enable it you won't be able to change it back to counting larger paper as 1 click instead of 2.
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
simply place the original A3 size paper on the glass,
now select the tray which have A3 size paper in it,
now press the "start" key.
you will get A3 to A3 copy....
