Hi, All my dashboard lights work on low beam. But when I turn on High beam, I'm not able to see any dashboard lights except high beam blue indicator (The odometer, fuel indicator, RPM indicator lights are NOT visible)
SOURCE: no driving or high beam headlights
To my knowledge a 2003 Toyota Camry uses a dual filament halogen bulb, either by Osram, Philips or Sylavania. If on the dashboard, the blue indicator lits when the switch is moved to bright or the passlight is engaged but no headlight, then it could jut be busted bulb (or part of it since you still have driving/low beam). In some cases, it could be the relay that supplies power direct to the bulb. At other times, it could be fuse(s) assigned to high beam. At certain instances, it could be also a loose, corroded or burned connector.
Corrective measure for your concern would be to check the 2 bulbs. This is performed by removing the rear covering (rubber or plastic cap) of the headlight assembly from the rear. The bulbs are held in place by a spring clip that needs to be unlatched from the base/holder. Carefully remove the bulb taking care not to touch the glass envelope. The filaments would be readily visible and cut/breaks would be apparent. If determined that one of the filaments (high beam) is open, replace the bulb(s).
If the bulbs prove to be OK, you need to work yourself backwards tracing the wiring harness. After the bulb, check the 3 prong connector for any corrosion or scorching/burnt marks; clean as maybe required. Next to check would be the relay that provides the +12VDC and then the fuse.
I doubt if the dashboard or steering wheel components involve with headlights may be at fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: head light not working on high beam
When dealing with wiring on a vehicle, it can go from something real simple, to something real complicated, in a hurry!
1.Checked to make sure the headlights have high beam? Bulbs are good in that respect? Not trying to insult your intelligence, but sometimes it's the simple things we overlook. Again, not trying to sound 'Uppity', but do you have access to a type of jumper wire, that has a needle type of tip on both ends? This way you can stick the needle tip, into the wire that has 'juice' for the low beam side of the headlight, and touch the high beam side. See if the high beam comes on.
2.Sometimes it's as simple as a bad ground. There is a wire, or wires, that come out of the headlight wire loom, and have a rounded metal terminal end. A machine screw, goes through the hole in this rounded metal terminal end, and fastens it to the metal sheet metal of the body.
The metal frame of a vehicle, and the metal sheet metal, is the ground for a vehicle.
A lot of times, where this rounded metal terminal end is fastened to the sheet metal, (Or frame), rust can develop between them. Between the metal terminal end, and the sheet metal. This makes a bad contact for grounding.
There is enough of a ground source for low beam headlights, but not enough for the additional draw of the high beams.
3.In the headlight wire loom, there is a Fusible Link. This looks like a 1, or 2, or 3 inch large bump in the wire. This fusible link is designed to melt inside, and break contact, should it need to. Sometimes it's readily apparent when you view this fusible link. It will have the plastic covering melted on one side, or partially around. Sometimes it's not so obvious. (Isn't wiring fun(?)
You just have to use the probes, (Needle tip is real nice here), on a multimeter, (Set to DC voltage, and the 50 volt scale), and track from battery to headlight switch, to headlights.
4.Lastly, it may be the headlight switch itself.
SOURCE: Fuel indicator
OK, your fuel indicator is wired to a sending unit that is located inside the fuel tank. this assembly is part of the fuel pump assembly. the fuel indicator sending unit is housed in the same assembly as the fuel pump. The fuel indicator will not function properly if there is a bad ground or, if there is a fault within the sending unit. there is a floater device attached on this assembly and, it raises with the fuel level and lowers when the fuel level is low, sending resistance signals to the indicator gauge on your dash board. these signals can be disrupted if the ground is corroded or, if the sending unit is damaged. In most cases, replacing the sending unit will fix this issue. if the fuel indicator is stuck on the full mark, check the ground. if the fuel gauge is laying on empty all the time, replace the sending unit.
SOURCE: 2001 Toyota Corolla high beam lights are not
Your switch must be working since your indicator is telling you when the high beams are on, so my guess is that your bulbs are faulty. The high beam part. They probably burnt out one at a time, so you didn't notice until the second one went. Change your bulbs, and see if that solves it. If not, let me know.
SOURCE: low beams dont work, only high beams do. 02 tacoma
If there is power there, then it has to be the bulbs. The trouble that most people have is, they don't see how both bulbs could burn out at once... and they're right. They don't. But you see vehicles with one headlight all the time. They don't know it unless you tell them or they happen to see it themselves. Then the second light burns out, and they think it's a major catastrophe, when in fact, it's just bulbs. The high beam still works because the bulb is double filament. The only other thing it can be is the dimmer switch, and since you switched it to high, it appears to be working. However, if it's not bulbs, it still could be the switch.
