Zyxel P660HW-D1 Router Logo
Dody Kluttig Posted on Apr 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Find wep key - Zyxel P660HW-D1 Router
Lewis Meyer
Level 2:
Scholar:
New Friend:
  • Expert 140 Answers
  • Posted on Apr 24, 2014
Lewis Meyer
Expert
Level 2:
Scholar:
New Friend:
Answers
140
Questions
Helped
36096
Points
304
Wep key in on the side, back or bottom of your router. usually about 15 or so numbers and letters. Mac key ore pc key etc.
How can I find my WEP key?
Check on the bottom of your router or wifi router or on the side its your security key to hook up the device to your other devices.
A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:examples below
  • 1A648C9FE2
  • 99D767BAC38EA23B0C0176D15
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
2helpful
2answers
What is a wep key and how do i find it
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi Routers and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other.
We are trying to sign on to our home network but the WEP key, after entering, keeps saying settings are invalid. What exactly is the WEP key? What do we need to do?
Are you trying to connect to your internet connection for wireless? If it is, the WEP key is the password that you set up for your wireless device so that devices that can see the your wireless network will be able to connect by entering the right WEP key. If you didnt change the WEP key of your modem or router, then the default WEP key will be found at the back of your device, but if you had changed it before then, that's the WEP key that you need to enter.
2answers
I need to know what the wep key is
4helpful
What is the wep key
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:
  • 1A648C9FE2
WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi routers, adapters and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other. The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
2answers
Informed WEP key is a 10 digit number. could 231408&sid nos. & characters be my WEP key?
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
What is a wep key, and where will i find it, for setting up xbox 360 thanks
WEP stands for Wireless Encryption Protocol and it is the wireless key for your router.
You will need to find the WEP key in your router's administration page and then enter it on your xbox under the system settings then network settings.
I need wep key westell model 327w
Unfortunately, no one could not provide you any WEP key. WEP is a key that you set to your router so that no one could connect to your wireless network. As an owner of the network, you should know what your network key was.
If you forgot your WEP key, you need to reset the router to factory default, configure it and set a new WEP key.
That is the only way. Thank you!
1helpful
2answers
How do i reset my wep key or locate my old one
To locate your wep key.log into the router under wireless security there you should see it.If not you can use a paper clip to reset it.The hole is at the back next to the ports.
Good luck
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
