SOURCE: my compaq deskpro EN has a corrupt image screen
reinstall or upgrade your bios. also your bios will have an option to disable the logo so first try to disable it and then enable it again
SOURCE: power problem with HP Compaq d530 Convertible Minitower Desktop
Try this first : Load the bios (F10 - vista or F1 - XP), Load setup defaults F5. then Save changes F10, and try restarting your pc.
Secondly, after restarting your pc, on the HP invent screen, keep tapping on F9 for the diagnostic test
If theres no any error message, press any other key ACCEPT for the 'R' key to restart or repeat the test.
Other sollution
Try loading into safe mode F8, select on the safe mode and let the computer stays into safe mode for sometime.
If the pc doesnt restart, it means theres no any HW problem in ur pc. If it does the same, it means, you will need to check your Power supply, M/board with your tech
