No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
1 Press the "Fn"+"F2" buttons on the keyboard to turn off wireless for Dell laptops D600 and D610. Press "Fn" + "F5" and then click "Turn On" to put IBM laptops T43 and X32 in airplane mode.
2 Press the "Airplane Mode" button on HP laptops. Look for the button either above the laptop's keyboard, along the left side near the USB port or on the front side.
3 Press the switch located either on the left or right side of the laptop to put Toshiba laptops M1, M2 and R100 into airplane mode. The switch is located next to the volume control on Toshiba laptops TE2000 and Tecra 2100.
4 Click the "Start" button and open the "Control Panel" and click "System." If the laptop has an airplane mode control installed, it will appear here.
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢) NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active. To turn Airplane mode on or off, refer to the following: ---------------------------------------
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps: 1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps: 1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
>on your iPod screen, go to Settings
>and once the Settings window opens, you'll find the Airplane Mode on the top of it. Now, just tap on the switched button beside it to turn it ON or OFF.
