Car Audio & Video Logo
emily juilfs Posted on Apr 23, 2014
How hook amp up to a oem integration SNI-15 line output convertor
Ray Lozano
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Apr 28, 2014
Ray Lozano
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
7852
Points
62
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
I am trying to install my Pac sni-15 converter box to my 99 Lexus es300 using one door speaker
Sub Amp with stock head unit write up JKowners com Jeep Wrangler JK...
I included a link which provides information on the hook up. It is not specific to your car, but it may have some good pointers.
You haven't specified what problems you are having with the hook up. If you provide a detailed description of the problem , I may be able to help further.
2004 Tahoe Line Output converter
You can get the signal wired behind the radio or if it is more convenient you can tap into the rear speaker wires in the colums in the rear of the vehicle which will make your rca's from it be shorter to the amps in the rear.
I have a Pioneer VSX-520 receiver and was told I need a pre-amp to hook up my record player.I purchased a technics integrated power amplifier from a flea market and was wondering if it is compatible with...
IF the unidentified new Technics Integrated Amp has a PHONO section it will support the turntable.
IF the unidentified new Technics Integrated Amp has, say, a Tape Output, that could feed any Line Level input on the Pioneer. OUT to IN.
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
How Do I Wire An Amp To A Factory Stereo Without Rca Jacks
Hello jon101478,
Purchase a line output converter (LOC) such as the PAC SNI-45T shown here. Tap the LOC inputs into your rear channel speakers and run RCA's from the LOC to your amp. The unit shown in the link also has a trigger wire that you connect to the remote terminal of your amp. You can get a cheaper LOC and just run a switched 12V source to the amp if you wish.
Hope this helps.
1helpful
Hooking up system to a factory infinity sound system in a jeep grand cherokee.
Tap into a signal wire (rear speaker wire) using a line level converter.
These convert the High level speaker wire output into low level RCA output that is accepted by your amplifier.
c5b61ef.jpg Get a good one Pacific Accessory Corporation (PAC) sni-35 is the best IMO.
The TRUNK-LOC is the SAME as the SNI-35 - but it incorporates a voltage sensing input - so you dont need to run an additional turn-on wire. The voltage is sensed through the speaker wire - and it turns on the amplifier.
Then you will need a fused power wire from the battery,
Ground to chassis, and remote turn on lead (if you use a standard line level adapter).
An amplifier installation kit will give you everything you need to add 1 amplifier (except the converter)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
I have a rockwood Amp-479X, need directions to install
Hello william_pric,
Look on the speaker output terminals to see if there is an indication, usually a line between the positive (+) on one to the negative (-) on the other, with the word "bridged". If the bridging terminals are not indicated, you can always try one of the positives and the other negative. If there's no sound, it must be the other two terminals. Just be careful that you don't short the terminals, and don't crank the volume up without the sub connected. Some amps don't like an infinite load.
For an input to the amp from a stock OEM radio, your best solution is to use a "line out converter", connected to the rear speaker wires. The PAC SNI-45T shown in the link is one such device. This one includes a "remote turn-on" lead for the amp. You could use a cheaper LOC and just run 12V from an accessory lead on the truck. In this case, the amp will turn on and stay on whenever the ignition switch is in the "on" or "accessories" position. If this is objectionable, mount a SPST switch somewhere convenient and wire the turn-on wire through it.
Hope this helps.
How do i install an interfire IB2400c amp?
Hello blown1914,
That appears to be a good amp and should power your subs with no problem.
You will want to install a line-level converter to your stock speaker outputs and use RCA cables to the amp. Here's a link to SonicElectronix line-level converters. The PAC SNI-35 is OK if your stock radio has a remote turn-on lead. If not, you should probably look at the PAC TRUNK-LOC. It still a 2-channel line output converter but also includes a trigger output to power on your amp.
http://www.sonicelectronix.com/cat_i331_line-out-converters.html
I tried Interfire's web site to see if they have a downloadable manual for your IB2400c amp. I could not find it, so it may be that it is no longer in print or no longer available.
You may want to go to their support page (link attached) and send them an email.
http://www.interfireaudio.com/contact.html
Hope this helps.
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
