If your going to use a secondary program to fetch drivers for you, driverguide is a joke it only allows a limited number of retrievals and most are way out dated and also will give incorrect drivers. Find the manufactures site and check for the latest driver. Some have their own software to located what driver you need for the hardware. For instance Dell I have a inspiron laptop needs wifi driver wireless 1704. Nothing on my unit in the papers with it or even in device manager told me this. Dell has a program called bootstrap which scams your system and relays driver and updates.Sometimes a specific unit may have a few configurations depending on it factory ordered or store bought. This can make a little work if a list of possibilities shows. Luckily in my case there was 1 listing. .
If you do want to go the route of using a secondary program I would suggest SlimDrivers They stay on top of all drivers. I had to find a sound driver that come to find out the company no longer provides service of such (soundmax) Driverguide gave ma and update for soundblaster (2007). I installed it and ended up with no sound what-so-ever. Slimdriver looked it up and found the very last time it was put out (2003).
SlimDrivers Free
Yes there is a paid version but there isn't really any difference other than No ads and a little quicker in search. The ads are primarily at the end of an install and for you to buy the program.
DID YOU EVEN LOOK AT THE QUESTION BEFORE YOU ANSWER IT THE QUESTION WAS HOW DO YOU TURN ON THE WIFI NOT HOW DO YOU INSTALL THE DRIVERS. PLEASE READ COMPLETELY BEFORE YOU ANSWER. THANK YOU.
SOURCE: Compaq Presario X1000 laptop
have a look on the web for the "X1000 Maintenance and Service Guide", which contains full disassembly instructions. All you need is a cross-head screw driver and a bit of patience. The Graphics Card (an ATI Mobility Radeon 9200) has a couple of screws and then just plugs into the motherboard - no soldering required! You can usually find these cards at reasonable prices at a well known auction site.
SOURCE: need wifi driver for presario c754tu with xp pro support
try visiting your laptops vendor website and download your driver for windows xp, just have patience or email me @ [email protected] and i will gladly help you download your driver
SOURCE: compaq presario c700 laptop
You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
SOURCE: how to turn on wifi device on my compaq presario
go start->settings->network connection-> u see wireless network connection
right click and chose enable
SOURCE: how much ranm can presario x1000 handle
This laptop has 2 x memory slots.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.
1GB, 200-pin SODIMM, DDR PC2700 memory module
