Started to turn itself on by itself yesterday and today it just leaves itself on and scrolls threw all the channels non stop... please help
SOURCE: Technical problem(please help)
If your TV is the 42EP24S model, get the TV-3940-01 repair kit if you can. If you cannot get that kit, get the 6871VSNB03E kit. Rich-Tech has it for $198. Unfortunately Rich-Tech's kit does not include the EEPROM so how long the repair will last is unknown.
SOURCE: Menu Scrolls Uncontrollably
The most common cause of the problem is a stuck/shorted button
either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control
battery or put it away from the television. Press the menu button on
the television and check if the menu scrolls by itself. If yes, the
DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Testimonial: "You are the best my friend, thanks alot for the help, apreciate it."
My haier plasma monitor blinkred and than blue light..when you put the power it clicks frist 2 times and than 1 more time.please help.
and none of the buttons on the side of the tv work when it does this
