I remember this happened once before and I had to press a button or a combination of 2 buttons, but I can't remember which one(s)
SOURCE: pioneer DEH P4100 Volume Stuck
if all you need to do is get the cd out there is a small hole in the foront of the unit just big enoufe for a papper clip just stratien one out and put it in the hole but if you want to fix your unit then you will have to take the face plate apart get the soda out of the face plate i always use glass cleaner and cotton swabs for this just make shure you get any and all residue off before you put it back togethr and make shure you clean the rubber pads under the buttons and you should be good to go
SOURCE: Pioneer DEH-1600 car stereo,cd
push and hold the audio button then push and hold the clock button and it should work.
SOURCE: Changed car battery and now Pioneer DEH-P7700MP doesn't work
check behind radio for inline fuses . useually on red and yellow wire's . most likly blew one . or fried radio all together . most likely just fuse , thats why they are there
SOURCE: i have a pioneer mosfet deh-2900mp car stereo with
radio off press and hold the audio, sound or info button
it only teks 3 to 4 seconds , the radio is goin gto turn on on menu mode, you have to find the cd changer and turn it off,also find the aux and turn it on
you can also turn on and off many other functions
it is only 1 button
good luck
