I wan to install windows xp on the server ibm system x3500 server
SOURCE: hard disk no detect in installtion of window
You need to give windows installation the drivers for your Sata-Bus by pressing F6 while the installation load the drivers (like when we want to install on RAID drive). or do the following method follow the links in that page for Slipstreaming VIA Serial ATA drivers and the other link to create a boot CD Creating a bootable Windows CD with Nero.
it's all in the following link: http://weblogs.asp.net/jkey/archive/2005/08/28/423901.aspx
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
SOURCE: how to install windows server2003in ibm server x3400
The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
Good Luck
Franklin
C2Solutions
SOURCE: ibm x series 226 attempt to install os and says no harddrive
you need to press f6 to install third party raid drivers when setup starts...then set will ask you to insert the floppy containing the files...It will ask you when you get to the same screen that tells you no harddrive found....The raid drivers are on ibm's website...just takes a min of poking around
SOURCE: About ibm server x3400 drivers
You can download the drivers from IBM's website:
http://www.ibm.com/support/us/en/
